hej folkens.
Her er en foreløbig liste. Sig endelig til hvis I ser noget der ikke holder :shock:
Når listen er i orden skal den jo nok over i gruppekøb ?
Hvordan ser det ud med datoen ?
Hvor mange er stadig på. (jeg er klar
1 stk (Peluso) CEK-12 ("AKG") Style 34mm $195.00 USD
(eller soundking ?)
1 stk EF86 Audio Pentode (måske PF86) 75,- kr
1 stk Noval pcb socket (for EF86) 17,- kr
SC sound:
Lundahl 1538XL 350,- kr, ved 10 stk. Ellers 390,- pr stk
RESISTOR, METAL OXIDE, HIGH-VOLTAGE, AXIAL, +/-1%, 2KV, +/- 200PPM, 1G OHM 2508918842 22,- kr
33M 247-7783 7,- kr
MBB 0207 1% 470K 506-5620 0,5,- kr
MODST. METALFILM 0,5W 100K 149-925 0,5,- kr
MODST. METALFILM 0,5W 10K 149-818 0,5,- kr
MODST METALFILM 0.6W 1.6K 148-556 0,5,-kr
MODST. METALFILM 0,5W 220R 149-650 0,5,- kr
AUDIO KONDS 100UF 35V 215-5714 10,- kr
1822 MKT Polyester Cap,160V,2.2uF 166-6099 30,- kr
MKS4 Polyester Cap,63V,1uF 108-2980 18,- kr
POLYESTER CAP 250V 100NF 537-3325 5,- kr
Polystyrene axial capacitor,10nF 160Vdc 113-409 23,- kr
Polystyrene axial capacitor,1nF 160Vdc 113-320 12,- kr
PCB, bestilles hos Gustav 50,- kr
PSU::
7MM CERMET TRIMMER 4K7374-6917 6,- kr
El-Supply
5638 TRANSFORMATOR 1 x 9V/12VA 60,45
5639 TRANSFORMATOR 1 x 12V/12VA 60,50
eller RS
PCB mount transformer,5VA 2x0-9V o/p 347-2537 41,- kr
TRAFO (PRINT) 3 VA 2X0-15 V 805-546 35,- kr
1 pcs. IC-Regulator, LM317. 15,- kr
ENSRETTER, BRO.1.5A/400V 659-832 4,- kr
TSUP Al electrolytic cap,470uF 200V 414-8831 31,- kr
Al electrolytic cap,PS,25V,2200uF 519-4100 10,- kr
Non-polar electrolytic NK cap,35V 1.0uF 521-1839 1,- kr
RESISTOR, METAL FILM, MIL TYPE, AXIAL, 0.25W, 2%, 1.8K OHM 2509262825 5,- kr
7MM CERMET TRIMMER 4K7 374-6917 6,- kr
0.25W FLAMMESIKR MODST 470R 267-1648 0,5,- kr
Modstand kulfilm 1W 10K ohm 131-895 0,5,- kr
LC840 - METALKABINET 150*180*80MM (vejle-rc.dk) 160,- kr
OMSKIFTER DREJE- 1-POL 12-STIL 320-679 11,- kr
IEC Fused powerinlet + fuse T315mA 21,- kr
Main powerswitch tybe T400 21,- kr
power indicator light 15,- kr
Thomann
NEUTRIK NC7MDL1 7pole male 46,-
NEUTRIK NC 7FDL 7 pole female 31,-
NEUTRIK NC 3 MD-V 3 pole male 31,-
NEUTRIK NC7MX male 47,- kr
NEUTRIK NC7FX female 70,- kr
SC sound:
mogami tube cable 7pole 30,- pr. meter
alle priser er + moms og for et stk.
Mine Mikrofon (body´s) bliver nok en anelse dyrere da jeg må få en af mine venner til at dreje bundstykket.(stadig billigt synes jeg). Jeg er ved at konstruere et shock-mount. Mere om det senere.
