G7 Beställning - Hjälp!
Startet af vstCalle, December 07, 2006, 11:56:10 AM
vstCalle
Jag mailade Jakob på Gyraf detta och han hade inte tid och tipsade om att ni var helt grymma o säkert kunde hjälpa mig  :P  :?:  :!:
Tack på förhand!:
"Hello Jakob!
I've tryed not to contact you since I assumed that you get a lot of questions regarding all of your DIY projects...but I still have some questions regarding parts for the G7 microphone... Rolling Eyes
I've got three Iaudio bodys and Dale's M7 capsules..so that part has been taken care of...and the Lundahl I'll manage (I live in sweden so maybe it's a little bit easier for me ;)!
Now I'm going to order the rest of everything..allt the stuff for the PCB's and the Tubes..and I've tryed to follow your "Components List" but I've stumbeled over some questions...
My goal is to buy only the best components to make thess microphones as good as they can get...the only thing that I'm trying not to spend a stupid amount of money on is the tubes since I've read that they don't really effect the sound so much in your G7 design?
I'm doing an order for all of this at RS Online (http://www.rsonline.dk) since I've read that they have everything an so forth..to make it easy..
If you could please check this list for components and maybe come with suggestions of changes (maybe with part numbers from their site?) I would be more than thankfull Heck Yeah!
I don't know anything about watts for the parts or what kind to choose and so forth..only guessed and tryed to folow your list..
This is what I got to this far:
"G7 Mic
247-7856 - Resistor,highRic,thick film,metal glaze,0.25W,1G
247-7783 - Resistor,highRic,thick film,metal glaze,0.25W,33M
214-3115 - Resistor,metal oxide film,power,3W,470k
149-925 - Resistor,metal film,0.5W,1%,100k
149-818 - Resistor,metal film,0.5W,1%,10k
148-556 - Resistor,metal film,0.25W,1%,1k6
149-650 - Resistor,metal film,0.5W,1%,220R
215-5714 - Capacitor,electrolytic,aluminium,audio grade,solder tag,35Vdc,100uF
166-6099 - Capacitor,film,metallised polyester,radial,1822,MKT,100°C,±10%,160V,2.2uF
108-2980 - Capacitor,film,metallised polyester,radial,miniature,MKS 4,100°C,±10%,63V,1uF
PSU
631-317 - IC, Voltage Regulator, Positive Adj, LM317T
414-8831 - Capacitor,electrolytic,snap in,2 pin,TSUP,200V,470uF
315-0631 - Capacitor,electrolytic,aluminium,low impedance,radial,wire ended,25V,2200uF
547-8486 - Capacitor,aluminium,electrolytic,radial,subminiature,SRE,85°C,±20%,35V,10uF
148-562 - Resistor,metal film,0.25W,1%,1k8
374-6917 - Trimmer,Cermet,single turn,miniature,7mm,4.7kOhm
148-427 - Resistor,metal film,0.25W,1%,470R
214-1276 - Resistor,metal oxide film,power,1W,10k"
185-4347 - Capacitor,metallised polyester,axial,wire ended,400Vdc,0.1uF
113-409 - Capacitor,tubular foil polystyrene,axial lead,160Vdc,10000pF
113-320 - Capacitor,tubular foil polystyrene,axial lead,160Vdc,1000pF
347-2537 - Transformer,encapsulated,PCB mount,5VA,230V pri,2x0-9V sec
805-546 - Transformer,PCB mount,3VA pri,230Vac,50/60Hz,sec,2x0-15V
659-832 - Diode,Bridge Rectifier,W049
Any suggestions for what EF86 tube to use that is not to expensive and still good enough for the rest of the components?
Thanks a lot :) !
Calle / Sverige - Stockholm "
Tack på förhand för all hjälp ni ess där ute :D !
Hej Calle, og velkommen til!
Nej, Jakob har designet og lavet styklister osv osv. Resten må vi selv klare. Det er vel også meget rimeligt, ikke sandt? :wink:
Black Dog herude er den eneste foreløbig som har lavet G7 så han må rette mig hvis jeg siger noget forkert.
Sørg lige for at tjekke om alle de kondensatorer du bestiller skal være radial, axial eller hvad du nu bestiller. De skal jo passe i printene. (fremstiller du selv PCB'erne?)
Desuden er håndreglen at hvis der ikke er specificeret en Watt værdi for modstandene så er det tænkt at skulle være 1/8 Watt. Jeg tror dog de fleste bruger 1/4 Watt modstande.
Tjek tubes hos Tubetown og Pyndt. Find links i Webshops forummet her på sitet. http://www.tunetown.dk/forum/viewforum.php?f=6
Og tjek de andre shops også. F.eks. El-Supply sender gerne til andre lande end Danmark og de har rigtig meget af det vi skal bruge til vores projekter.
Husk at poste herinde så vi kan følge med i dit byggeri! :D
vstCalle
Citat fra: "Luny Tune"Hej Calle, og velkommen til!
I'm sorry but I'm to stupid to understand Norwegian writing..could you please re-write that in english?
Thanks  :P !
GustavG
Citat fra: "vstCalle"
Thanks  :P !
Det er dansk (tunetown.dk) try www.groupdiy.com  :wink:
vstCalle
Citat fra: "GustavG"
Thanks  :P !
Jo jag vet det :roll:
Och jag som trodde ni kunde engelska i Danmark :wink:  :?:
vstCalle
It's cool, Calle! But we made this forum specifically for communicating in Danish. For the exact same reason you would like an answer in english. Sometimes it just doesn't translate easily. See?
Groupdiy.com has TONS of info on all subjects already and repeating it in english here really would be silly. And there are many many brilliant people roaming there so you'll be in very good hands.
Finally may I suggest you tone down the attitude just a little bit when you post on groupdiy.com. Eagerness is absolutely fine but when it starts reading as a bit arrogant it tends to turn people off. I'm sure you're just eager to get going, so please take this as just a well meant advice. :)
They (we) are all in this for the hobby and to help and learn and there's always a really friendly and kinda cosy atmosphere out there (and here) so read a couple of topics to "get the lingo down". I'm sure you'll find exactly what you're hoping to find there. We all did, and regularly hang out there too.
See you there.:D
Best regards and good luck!
vstCalle
Citat fra: "Luny Tune"It's cool, Calle! But we made this forum specifically for communicating in Danish. For the exact same reason you would like an answer in english. Sometimes it just doesn't translate easily. See?
See you there.:D
Thanks a lot! No problem!
I have already posted a topic there earlier today..still waiting for a reply..thanks for you help!
